Simple three phase motor wiring question
Discussion in 'General Electronics Chat' started by oidium45, Sep 24, 2011.
  1. oidium45
    Thread Starter Active Member
    Apr 24, 2010
    130
    8
    Assuming that a motor is wired up to L1,L2,L3 (in that order) and it is moving forward. I understand that swapping two legs will cause the motor to go in reverse. For example: (L1,L3,L2), (L2,L1,L3), (L3,L2,L1). But what effect would this configuration likely produce? (L3,L2,L1), (L3,L1,L2), (L2,L3,L1).
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Just count the number of 2 wire reversals. Odd number, it runs backwards. Even number, it's turning the same way.
  3. oidium45
    Apr 24, 2010
    130
    8
    Eh? Odd number? Even number?
    Are you saying that if i have "one" two wire reversal it operates in reverse, and "two" two wire reversals will cause the motor to operate forward again?
  4. #12
    Nov 30, 2010
    16,705
    7,358
    The numbers 1,3,5,7,9 are odd numbers. The numbers 2,4,6,8 are even numbers.
  5. oidium45
    Apr 24, 2010
    130
    8
    Sarcasm is rarely helpful...
  6. #12
    Nov 30, 2010
    16,705
    7,358
    And you adding clarification to your question after I answered really makes me look sarcastic, but your premise in post #3 is correct. Every time you swap 2 wires, the motor reverses. Two reverses is back where it was in the first place.
  7. oidium45
    Apr 24, 2010
    130
    8
    Thank you! I appreciate the help.
    Just to clarify, i was updating the post during your response.
