You only said it once actually, but you did say it and I did miss it. sorry for that; I just came on the scene. you could do this easily with a microcontroller. connect your 2 RTDs to the the microcontroller and have it output a voltage (or current, might be a little more complicated if the motor controller is looking for current) proportional to the input of the lowest RTD.The controller does have a thermistor input. I think I have said this three times now... My problem is that I can't wire BOTH motors into it, and expect it to behave like I want it to. I'm beginning to think that parallel thermistors mightn't be so bad, but a couple of small current clamps will also serve as a good warning.
That's OKYou only said it once actually, but you did say it and I did miss it. sorry for that; I just came on the scene. you could do this easily with a microcontroller. connect your 2 RTDs to the the microcontroller and have it output a voltage (or current, might be a little more complicated if the motor controller is looking for current) proportional to the input of the lowest RTD.
well the good news is, with the way they show that 1KΩ resistor, it creates a voltage divider, so the controller is looking at voltage and not current. You could probably make a simple circuit with a comparator to compare which thermistor is lower in value and transmit the voltage to the the controller. or use a microcontroller.That's OK
For interest, this is the controller I'm using,
http://kellycontroller.com/racing-controller-kdh14121e24-144v1200a-pm-with-regen-p-601.html
and the manual is here:
http://kellycontroller.com/mot/downloads/KellyKDHEUserManual.pdf
In the wiring diagram towards the end (page 12) you will see one of the leads goes to the thermistor and return via the throttle ground.
We learn new things every day!... MOSFETS don't behave properly at voltages above ~110 V...
