OK, the improved Schmitt Trigger helped. Still not right, but the transistor is cooler (but hot). I can see a definate duty cycle improvement looking at VR2,3. I've decided to skip R10, and replace the transistor with a TIP107, a Darlington PNP. I've also bought some 3A Shottky's (1N5821) to try out.
Success! It is finally converting. 1.89A in, 2.15A out, the new transistor is better, still getting hot, but I have it well heatsinked, and everything is good.
I don't like the Q2 arrangement one bit, but this aspect of the project is complete. I'll be following up with another diagram eventually.
Lessons learned:
The Schmitt Trigger is critical. You need as wide as swing as you can get by with. The op amp does not go rail to rail, you have to compensate for that somehow.
Apparently a Schottky is pretty important. I still think a conventional diode will work, but I knew the diode might be under rated. I'm not sure if this is a rule, but you need to match the diode current to the output current.
Final Schematic
Switching Regulator Parts List
U1 JRC4565 (1458 style dual op amp w/ better specs)
VR1 10V zener diode, 5W
VR2, 3 3mm Red LEDs
VR4 10V zener diode, 1W
Q1 TIP107 PNP Darlington power transistor
Q2 2N2222 NPN transistor
D1 Red LED
D2 Green LED
CR4 1N5821 3A 30V Schottky
R1, 11 1 KΩ ¼W resistor
R2 2KΩ Variable resistor
R3, 5, 6, 7 10KΩ ¼W resistor
R4 7.5KΩ ¼W resistor
R8 4.7KΩ ¼W resistor
R9 150Ω 1W resistor
R10 360Ω ¼W
C1, 2 470µF 35V Capacitor
L1 350µH
Lessons learned:
Final Schematic
VR2, 3 3mm Red LEDs
D1 Red LED
D2 Green LED
R9 150Ω 1W resistor
R10 360Ω ¼W
L1 350µH
