Simple switching power supply filter cap value
Discussion in 'General Electronics Chat' started by RichardO, Oct 12, 2016.
  1. RichardO
    May 4, 2013
    1,350
    432
    I found this schematic at
    http://electronics.stackexchange.com/questions/106862/smps-with-two-outputs-12v-3amax-24v-2amax
    It is similar to the wall wart I have.
    What I don't understand is how the filter cap can be such a low value. It seems to me that the ripple would exceed the power line peak voltage at 120 volts in. Any thoughts would be appreciated.
    Also, does anyone have an LTspice simulation for this or a similar circuit so I can see better what is happening?
    edit: Oops. I meant this to be in the chat forum. Can a Mod move it?
  2. WBahn
    Mar 31, 2012
    18,094
    4,920
    MOD NOTE: Moved to General Electronics Chat from Homework Help at TS's request.
  3. tindel
    Sep 16, 2012
    576
    196
    Rich - my back of the envelope calculations also have 10uF being too small. 100uF is a bit more realistic - but I'd say 470u is probably best.
    I think of it two ways.
    First think of the Power out - 60W. Say you get 70% efficiency (pretty standard for this type of flyback) - that means your input has to supply about 85W - or a resistor of 345 ohms hanging right off of the primary DC rail. The attached plot shows that the vin rail tanks with this large of a load (also note that the average power is nowhere near 85W - further indicating that the input voltage will tank).
    As a double check - think of it in terms of energy -
    with a 60W load, you expect 60J/s output energy - over about 8ms - that's about 0.5J per 120Hz cycle. Again assume 70% efficiency - or about 0.7J. A 10uF capacitor only stores 145mJ at 170Vdc (0.5*C*V^2) - that's not enough energy storage in the cap to supply the load for a full half cycle - again confirming that 10uF is probably not up to the task at hand. 100uF stores 1.445J at 170Vdc - so you'll expect 50% voltage ripple with a 100uF cap. A 470uF cap is probably the best option for reasonably low ripple... as it will store about 6.8J of energy and you'll see about 10% ripple.
    Of course - this doesn't account for the energy that the line provides directly - which will further reduce the ripple, but this is a good 'first-order' calculation.
  4. tindel
    Sep 16, 2012
    576
    196
    Another thing that makes the situation worse is that the supply input is negative impedance (i.e. input current actually goes UP as voltage goes down to maintain a constant output power).
    Finally, (I hope, and you probably do too) - Flybacks aren't great at these kind of power levels. Somewhat because Capacitors become so large and expensive that they quickly become uneconomical. A quick digikey search had the cheapest, in-stock, 400V 470uF cap at $2.62 in 1000 pc quantities. Yikes!
    http://www.digikey.com/product-detail/en/nichicon/LLG2G471MELB35/493-7237-ND/3768575
  5. RichardO
    May 4, 2013
    1,350
    432
    I think that the original circuit(s) are trying to minimize the capacitor size as a trade off with ripple voltage. Because of this, I suspect they would not even be happy with your 100uF cap. :eek:
    Since I posted the question, I did a crude simulation.
    Many of the values are guesses. Especially the transformer.
    The circuit is reverse engineered from a 12 volt, 1 amp wall wart I bought at MicroCenter. I think they claim that it will operate anywhere from 100 volts to 240 volts at the input. It does not seem to work as spec'ed and I was curious why...
  6. tindel
    Sep 16, 2012
    576
    196
    Rich - I made an egregious error last night when I posted this. I though deltaE=0.5*C*deltaV^2. I realized today that I was wrong, wrong, wrong! Sorry to steer you astray. DeltaE=0.5*C*(Vmax^2-Vmin^2). I'm going to blame it on being tired.
    So, solving for Vmin - you get
    Vmin=sqrt(Vmax^2-2*deltaE/C)
    Note that the 2*deltaE/C factor ends up being larger than the Vmax^2 resulting in a negative sqrt (and a imaginary number) when the capacitances are very low - and not adequate for the tasks.
    So Vmin and ripple the attached image. Note that this is not the whole truth - but is closer. The line actually provides up to 50% of the energy theoretically. The line adding energy adds a sine factor in the deltaE - and my algebra/trig is not good enough to solve for Vin for that equation.
    I'd say a of 47uF is the absolute minimum that reasonably work. A 100uF cap should work fine - with less than 20% ripple. However, you can also run into problems with wide voltage changes due to changes in frequency or duty cycle (based on if it's constant frequency, or not).
  7. tindel
    Sep 16, 2012
    576
    196
    And another quick screenshot on the 12W converter that you simulated. 15uF is pretty low - but you show that it might work with as low as 4.7uF. I know I wouldn't put my name on it.
  8. ronv
    Nov 12, 2008
    3,404
    1,501
    If you just want to check the cap size you can model it as a plain buck like this. You should be able to get the same results from the flyback, but this is easier to see. This is just a kludge of another circuit so I didn't have to draw and design, so don't think the parts are correct.:rolleyes:
  9. RichardO
    May 4, 2013
    1,350
    432
    Thanks. I will have a look at it.
  10. RichardO
    May 4, 2013
    1,350
    432
    Interesting results. I would not put my name on it either.
    I am trying to get the simulation more correct. When I put an actual model for the MJE13005 in the sim it does not oscillate. :(
    I did a search for:
    ieca-inc.com switching
    I found this application note and other interesting papers:
    www.ieca-inc.com/images/smps_design_guide.pdf
    www.ieca-inc.com/images/Conducted_EMI_filter_design.pdf
    www.ieca-inc.com/images/powersupplywhitepaper_10042010.pdf
    Moderators note: Please do not use bold in links as they will not work.
  11. tindel
    Sep 16, 2012
    576
    196
    http://www.mouser.com/pdfdocs/2-8.pdf
    Here is a design guide that I found helpful. I think it helped me identify a problem that was causing me to not be able to use the entire input voltage range on my flyback that I'm designing right now.
  12. RichardO
    May 4, 2013
    1,350
    432
    Thanks. There appears to be a lot of down to earth information there.
    On a related note. I finally got around to putting a "real" model for the ST13005 (MJE13005) into the LTspice simulation. The circuit would not oscillate.
    There was a bogus value in the Central Semiconductor model!
    I found a Motorola model but it does not work as expected in the circuit. It does not give enough peak current through the transformer primary. :(
    I guess I will look for yet another model...
  13. RichardO
    May 4, 2013
    1,350
    432
    I found a (probably soon to be end-of-lifed) part that looks interesting. What really caught my eye was all of the links to ap-notes in the data sheet.
    A lot of the ap-notes apply to the Fairchild chip but I suspect that they still contain good general information.
    edit: I looked at the ap-notes and they seem quite good. Lots of detail on general flyback switcher design. I have attached the ap-notes since the links in the data sheet did not work.
