Simple SR Flip Flop (NAND & NOR)
Discussion in 'Homework Help' started by jegues, Oct 15, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    I'm having some confusion in my attempt to fill out the following truth tables. (See figure attached)
    For now I've been focusing on trying to get the NAND FF figured out.
    I look at the table and the initial value I'm given for my NAND FF is as follows,
    S = 1, R = 1.
    Now from what I've read about the NAND FF,
    "It can be seen that when both inputs S = "1" and R = "1" the outputs Q and NOT(Q) can be at either logic level "1" or "0", depending upon the state of inputs S or R BEFORE this input condition existed."
    But I don't have any state of inputs for S or R BEFORE this input condition, this is my initial input condition.
    How do I deal with this?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    It doesn't really matter which value you will fill in the first row of your table, as the second row is the "reset" row. No matter what you fill in the first row, the second row will be 0-1.
  3. jegues
    Sep 13, 2010
    735
    43
    So I can choose any value I want for the first row of my table?
    I'm still a little confused about how I go about filling out my table, but I've made an attempt. How do things look so far?
    EDIT: How does that look? I'm still not sure what values for Q and Q' I should insert for the Invalid State.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    For my there is a error becaues in the table.
    For NOR RS flip flop when S = 1; R = 1 then Q = 0 and /Q = 0 so we have invalid state (in the logical sense).
    and for S = 0 and R = 0 we can not determine the output if we don't know the past.
    And for NAND we have invalid state for S = 0 , R = 0, but for S=1 ; R=1 we have the same situation as for NOR RS for 0 0 on input.
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Why you don't analysis the truth table for NOR; NAND gates.
  6. jegues
    Sep 13, 2010
    735
    43
    Okay so are you saying the first row in both my tables is incorrect? Or are you trying to tell me what the values of Q and Q' should be when there is an invalid state?
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    @Jony130
    Can you rephrase post #4 please? I don't think I understand what you say.
    @jegues
    I would write "Keep State" in the rows of the NOR FF where S=R=0. The action of the FF is a function of the inputs not Q and Q'. Also maybe you would be more correct if you wrote X's or ? in the first row. But I don't know for sure what are the intensions of your professor.
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    I'm trying to say that as for nor and nand gate the first row is not invalid state, it's stead state.
  9. jegues
    Sep 13, 2010
    735
    43
    Okay but what about the last row, they are invalid state's for both the NOR FF and NAND FF.
    If it's invalid how am I suppose to come up with values for Q and Q'?
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
  11. jegues
    Sep 13, 2010
    735
    43
    Okay, now I've got to fill out a truth table for the a Gated SR Latch.(see figure attached)
    For the first two columns, "Before applying clock", all the values for Q and Q' should be the same, correct? Because when the clock is 0, the Gated SR Latch should keep its state.
    For the second two columns, "After applying clock", this should be identical to a regular SR NOR FF, correct?
    Is what I stated above correct?
  12. Georacer
    Nov 25, 2009
    5,151
    1,266
    When the clock is LOW, you get S=R=0, the "no change" state.
    When the clock is HIGH, you get the actual values of S and R transfered to the NOR gates.
    So, yes, you treat it in the same way.
  13. jegues
    Sep 13, 2010
    735
    43
    Okay so the first two columns, "Before applying clock", should consist entirely of 0's?
    EDIT: Wait, then the values for the first two columns (Q, Q') will be identical to S&R right?
    So from top to bottom,
    0,0
    0,1
    0,0
    1,0
    0,0
    1,0
    0,0
    0,1
    1,1
    Right?
  14. Georacer
    Nov 25, 2009
    5,151
    1,266
    It's the same dillema as before. No matter what you fill them with, won't affect the next rows.
  15. jegues
    Sep 13, 2010
    735
    43
    Yes, I agree that they can be anything, but is there any specific values I should be filling with?
  16. Georacer
    Nov 25, 2009
    5,151
    1,266
    If I were you I would fill with X's, like don't care. But if the professor has directed you elsewhere in the classroom, by all means follow his instructions.
