Simple Spark Gap Circuit
Discussion in 'The Projects Forum' started by kevin1337, Apr 25, 2015.
  1. kevin1337
    Apr 25, 2015
    8
    I'm working on a simple project and have run across a problem. Been a long time since I've done circuits and cant seem to get this problem solved.
    I need a simple circuit that when a switch is flipped it will produce a spark over a 3mm gap. Does anyone have an idea on how to do this? I've tried creating a simple/modified marx generator to create the spark but still no luck.
    Been using:
    1 Mohm resistors
    4kV 102 pF Capacitors
    9V Battery
    Thank you,
    kevin
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Given the voltage and the capacitance, the energy stored in the capacitor is 40 nano-Joules. I'm sure it is not enough to jump the gap. The dielectric strength of Air is 3 MV/m or about 9000 Volts for the 3 mm gap. I think you are a ways away from that level.
  3. kevin1337
    Apr 25, 2015
    8
    Thank you for the advice. How might I go about changing the circuit? I've tried putting multiple capacitors in series... up to four (4) of the 4K capacitors but still no spark. Is my charging voltage too low?
  4. kubeek
    Sep 20, 2005
    4,687
    805
    How is a capacitor supposed to create any spark? It will never make more voltage than the 9V you are putting in. You need a transformer or inductor to create any sparks.
  5. kevin1337
    Apr 25, 2015
    8
    Thank you kubeek.... I think that is what I am missing.
  6. BR-549
    Sep 22, 2013
    2,168
    416
    Try this.
  7. kevin1337
    Apr 25, 2015
    8
  8. blocco a spirale
    Jun 18, 2008
    1,457
    369
    I had to google the Marx generator as I had never heard of a passive DC voltage multiplier; It relies on the input voltage being high enough to reliably produce an arc so a 9V input is a non-starter.
    If the TS just needs big sparks;
    http://www.ebay.co.uk/itm/Boost-Hig...225?pt=LH_DefaultDomain_3&hash=item5d578158e9
  9. kevin1337
    Apr 25, 2015
    8
  10. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Marx generators work by charging capacitors in parallel and discharging them in series. This is how you get a higher voltage out than what you put in.
    In order to use a 9v battery to charge the capacitors, you'll need a driver circuit along with the transformer. You cannot run a transformer on DC.
  11. kubeek
    Sep 20, 2005
    4,687
    805
  12. kevin1337
    Apr 25, 2015
    8
    Blocco's idea of the Boost Step-up Pulse Power Module High-voltage Generator is exactly what I need. I was over complicating a simple solution. Didn't know this device existed.
  13. #12
    Nov 30, 2010
    16,665
    7,310
    I di
    I didn't know it existed, either, but it looks scary to me! 40KV on some tiny little hook-up wires? The diameter of the winding wires must be microscopic. Treat it gently. I don't think it will survive much abuse.
  14. kevin1337
    Apr 25, 2015
    8
    So #12 gives me another noob question....
    If I want a spark to last something like 0.1 seconds (or just a small amount of time really) then stop for like 1.0 second then make another 0.1 sec spark... then repeat over and over until a switch is hit. Is there an easy way of doing that?
  15. blocco a spirale
    Jun 18, 2008
    1,457
    369
    I have a couple of these modules and I can confirm that they are terrifying, but I haven't manage to destroy one yet.
    Lower voltage modules are also available:
    http://www.ebay.co.uk/itm/New-DC-3V-to-7KV-Boost-Step-up-Power-Module-High-voltage-Generator-1PCS/251541077786?_trksid=p2045573.c100033.m2042&_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=29479&meid=9c8ffe9335154039a5f41c08e0cf390f&pid=100033&rk=4&rkt=4&sd=251875437450
  16. #12
    Nov 30, 2010
    16,665
    7,310
    It's called an astable oscillator. Easily done with an LM555 timer chip. You will need to add a current carrying transistor to provide the 2 amps your module needs and you have to let it cool off enough. It is rated to run for 5 seconds before overheating but no mention of cooling time required. I don't think a 10% duty cycle would work. Too much heat.
  17. kevin1337
    Apr 25, 2015
    8
    Thank you, reading up on it now. Looks like this might work.
