* Simple scope question *
Discussion in 'General Electronics Chat' started by rougie, Dec 20, 2006.
  1. rougie
    Thread Starter Active Member
    Dec 11, 2006
    410
    Hello I have just purchased the st-16b 10 MHZ scope from Sinometer.
    I am inputing 2 volts dc at 1volt/div and I see the line on the scope at 2 major squares above the x axis. This is okay, however, if I switch to 2 volts/div, the line now goes to two little segments above the x-axis which indicates 0.4 volts which is wrong. It is supposed to be at 1 major square above the x-axis, right?
    Its like I have to re-ajust the horizontal base line every time I change the voltage/div deflection scale. Is this normal in every scope or is it that I am missing something?
    All help much appreciated!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No, that's not the way it should work. If you've established the position of the trace at 0 volts, then the deflection should be from that point. If your vertical sensitivity switch is miswired, it might produce such results. What happens with other settings?
  3. wireaddict
    Nov 1, 2006
    133
    If you bought it new or even used there should be a warranty policy unless you bought it "as is". If it's under warranty, list everything you find wrong & contact either the mfgr. or seller's customer service.
