Simple Relay HELP!!
Discussion in 'General Electronics Chat' started by geis, Oct 21, 2010.
Thread Status:
Not open for further replies.
  1. geis
    Oct 21, 2010
    Hello all! New to the forum and have a quick question.
    I'm not the greatest when it comes to simple circuit layouts but here is my problem. I am setting up my wife's car to have daytime running LED's that turn off automatically when she turns on the headlights. These LEDs will be a totally different set of lights. I know that most DTL are a dimmer to the existing lights but we don't want that.
    The picture shows what I am trying to get at. I believe I might have the connections to the relay mixed up.
    Hope you all can help!
    -Geis
  2. geis
    Oct 21, 2010
    New layout after some review:
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Please see the "Automotive Guidelines" thread that is stickied to the top of the forum.
  4. Jaguarjoe
    Apr 7, 2010
    770
    90
    Your second scheme will work except that the LED's will be glowing all the time the headlamps are off- like when you're parked and the engine is not running.
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    SgtWookie is right.
    If there are modifications needed, let them be done by certified mechanic at the garage.
    This way you are sure the things are done safely.
    Bertus
Thread Status:
