I am designing a simple radio beacon for 28mhz.
What is the simplest oscillator? I look for an ic, i think a vco (pll?) would work, easy to adjust with trim pot. The problem is when the battery runs down the frequency will shift so it needs a zener regulator, complicated.
How much voltage swing do i need on the antenna to get 5w output. 12v/50ohms=240ma*12volts = 2.9W (no good). I have never understood this.
