Hi, new to this forum. Hope I post in the right place...
Simple question here about the output characteristic of BJT (npn type), why the collector current (IC) will become 0 when collector voltage (compare to emitter) VCE becomes 0 even when base current is not 0?
In this case I thought current would flow from base to collector and to emitter equally, because are both pn are forward biased. Is there any reason that IB is not 0 while IC should be 0???
thanks in advance!
thanks in advance!
