Simple question - how to connect to the internet
Discussion in 'Computing and Networks' started by Sparky49, Jun 11, 2012.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi all.
    Yeah - I know I'm already on the 'net, but I'm trying to connect an old PC to the internet via my hub.
    IN my first picture, you can see the connectors on my hub, and on the second is the picture of the ports on my PC.
    Can someone suggest a means of connecting the two? By which ports, and by what sort of cable?
    Many thanks,
    Sparky
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    Can't see a network card in the computer...
    Sparky49 likes this.
  3. djsfantasi
    Apr 11, 2010
    2,902
    878
    Second that!
    Might be able to get a USB Network adapter - I do see USB ports...
  4. Sparky49
    Jul 16, 2011
    835
    417
    I'll give the USB option a try - could you give me a link to a cable which I would need?
  5. BMorse
    Sep 26, 2009
    2,675
    234
  6. Sparky49
    Jul 16, 2011
    835
    417
    Many thanks chaps.
  7. electronis whiz
    Jul 29, 2010
    519
    27
    you will need a network card of some sort. i normaly use PCI becuse i have old cards laying around so i just put one in the system. a usb is simpler to install but if you have niether use the usb it will e eiser. plug it in your dsl router it should get an ip adress from dhcp on the router. if not put in a private class c adress like 192.128.1.3 and a dns server used by your isp they should have told you this in install or look it up on there site.
  8. TonyScott
    May 9, 2012
    Network card and don't forget the driver (very important). :)
  9. Sparky49
    Jul 16, 2011
    835
    417
    Many thanks!
  10. RamaD
    Dec 4, 2009
    254
    33
    Have you connected already?
    The router appears to have a USB port, which can be connected to the PC with a USB cable, and the ADSL line to the ISP. Please confirm this with the router model.
