Actually, they rarely will blow, and that is why bonding is required. Earth returns are typcially very high impedance, unable to pass enough current to trip breakers/blow fuses. A GFI on the other hand will recognize leakage and tripWhy does a fuse blow or circuit breaker trip if a power tool for example had its live mains wire come in contact with earth ?
The point here is that the neutral wire IS bonded to earth at some point (or points) in any system using this sort of protection.How does a live in contact with earth allow any large current to flow at all if earth isn't connected to the return wire in the circuit neutral ?
Basically whats the use of a earth wire if earth is not connected to anything other than "earth" at the other end ?
