simple question about dimming halogen bulb.
Discussion in 'The Projects Forum' started by Tyler, Aug 3, 2007.
  1. Tyler
    Aug 3, 2007
    i have this bulb.
    http://www.lightingsupply.com/halog..._voltage_jcd_type_120_-_130_volt/g8_base.aspx
    it is the 50 watt one.
    Its awfully bright and would like to be able to dim it if i wanted to.
    My friend told me to pick up a 5k ohm potentiometer and wire it up.
    im wondering. can i use this potentiometer with Alternating current? will it work with this bulb?
    i got it from radioshack. item # 271-1714
    on the back it lists specs. i dont know what they mean
    Resistance: 5k ohms +-20% tolerance
    Rated Power: .5 watts
    sliding noise: <47mV
    any help would be great. and if you can suggest any thing else that would be better.. please speak up.
  2. whalebat
    Aug 3, 2007
    6
    Hi Tyler
    Have you considered using a lower power rated bulb.
    I don't think it's a good idea to dim a halogen bulb as it may not work correctly.
    Generally the lower the power rating, the less light generated.
    Heres a good link that may explain better than me.
    http://members.misty.com/don/bulb1.html#hb
    Specifications
    Means the resistance value isn't exactly 5K.
    The value can vary anywhere between 20% below or 20% above 5K .....
    (4K to 6 K).
    This is the power consumption the potentiometer uses in circuit.
    Less than 47mV of noise generated when the slider is move at say 20mm/s with say 20 Volts (or less if the rated voltage is less) across it.
  3. Tyler
    Aug 3, 2007
    thanks for that reply and link but.. what i really want to know is if that potentiometer above will work with 120v.. and will it actually dim the bulb successfully?
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    You need a proper dimmer circuit using a triac. Just putting a Pot in series with the bulb will only succeed in burning up the pot.
    Another consideration is that Halogen bulbs need to run at full brightness occasionally to stop the black discolouration you get in an underbright bulb.
  5. whalebat
    Aug 3, 2007
    6
  6. mrmeval
    Jun 30, 2006
    833
    I'd recommend getting a lower wattage one.
    You can dim halogen lamps but it requires some complex circuitry. A lab microscope light costs about $250.00 but does it well.
    If I could see what it's mounted in you might be able to add a filter but that's difficult to do safely without taking a lot of hazards into account.
  7. hgmjr
    Jan 28, 2005
    9,030
    214
