simple quasi-complementary
Discussion in 'The Projects Forum' started by CRY&PRAY, Feb 7, 2014.
Thread Status:
Not open for further replies.
  1. CRY&PRAY
    Jan 6, 2014
    84
    Hello guys :) i've found some old germanium transistors (ASZ15) and i would like to build an amp with them, nothing too complex, just a amp with that germanium sound ;) just i don't know where to start, i want to create a simple quasi complementary (they're both PNP) amp, any ideas? i can't even found a datasheet about them! (kinda found something..)
    -Francesco
  2. nigelwright7557
    May 10, 2008
    488
    71
    You could use a silicon based transistor design if you altered the bias network for germanium.
  3. CRY&PRAY
    Jan 6, 2014
    84
    my bad, i've posted this thing 2 times, and the problem is that i don't know ho to do a simple class A with PNP, and they're germanium and that means different voltages and all that stuff. i'd like if you switch to The main Thread ;) i'm gonna close this
  4. MrChips
    Oct 2, 2009
    12,642
    3,457
Thread Status:
