simple python script not working properly
Discussion in 'Programmer's Corner' started by donut, Jun 12, 2012.
  1. donut
    May 23, 2012
    51
    Using a online source to get a quick review of python from beginners perspective.
    http://oopweb.com/Python/Documents/easytut/VolumeFrames.html
    just trying to run the following script:
    #This programs calculates rate and distance problems
    print "Input a rate and a distance"
    rate = input("Rate:")
    distance = input("Distance:")
    print "Time:"
    distance/rate
    I expect this to happen:
    Rate:5
    Distance:10
    Time: 2
    Instead I get this
    Rate:5
    Distance:10
    Time:
    Why am I not getting a value for time when i run the script?
  2. Markd77
    Sep 7, 2009
    2,803
    594
    Try this:
    print "Time:" + str(distance/rate)
    With the code as it is the result will be rounded to the nearest integer.
    <ed>Actually it depends on what you type at the input:
    Rate 12 and distance 1000 gives a different result to rate 12.00 and distance 1000.00</ed>
    donut likes this.
  3. donut
    May 23, 2012
    51
    that did the trick. just curious how/why did you consider using str(distance/rate)
    and why didnt the training source I'm using
    know that the script wasnt going to work without str(distance/rate)?
  4. Markd77
    Sep 7, 2009
    2,803
    594
    I tried distance/rate and that gave an error, and I had a vague recollection that using str was the way to fix it.
    Have a look here:
    http://www.tutorialspoint.com/python/python_variable_types.htm
    Here is how to make it always display the result with fraction:
    print "Time:" + str(float(distance)/float(rate))
    There are probably other ways.
    <ed> It will probably cause an error if text is entered, so it's usually worth checking input to make sure it's compatible. </ed>
