Simple PWM-USB adapter
Discussion in 'The Projects Forum' started by pcfist, Oct 2, 2013.
  1. pcfist
    Oct 2, 2013
    Hi guys!
    I'm looking for simple solution for a PWM to USB converter, going to use it to get readings from some sensors with PWM interface. I have experience in low-level USB driver programming, so I'm ready to write a driver/firmware for the adapter if needed.
    Can you recommend any hardware I can use for this?
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    If this was my problem I'd toss a Microchip PIC at it, programmed as a serial port device (CDC class). MC has free code examples that can be simple adapted to read the pulse info and then send it back out the USB.
    Lots of other processors could do this too, I'm just familiar with these.
    I don't know of anything else off the shelf.
  3. GopherT
    Nov 23, 2012
    6,310
    4,031
    What is the frequency of the PWM signal?
    At what resolution of duty cycle to you want (need) to measure?
  4. pcfist
    Oct 2, 2013
    Thanks for your suggestion, heard a lot about PIC but have no experience with it. Looks like a good option to me.
    Honestly I don't know because the datasheet does not say anything about frequency (directly at least). There is a sample of how to use this sensor with Arduino and Grove Base Shield, but it doesn't mention frequency too.
