Hi there,
I just got myself an XLP 16 bit dev board with a PIC24F16KA102 (you can find the datasheet here), and a PICkit3 to program the thing.
I was wondering if you could please help me? I am new to PIC24s and I have a few questions:
Many thanks
- I put my scope leads between pin 28 (Vdd) and 27 (Vss) and the voltage spikes for less than a second then drops to 0. It happens every time a touch the pin. Why can't I see constant 3.3V? I did check that power is on in MPLAB (at 3.3V), and the demo boards features were active (puts an LED on when you press a button, for e.g.). I also see the power LED of the board is on.
- The code below to see if I get an oscillator signal out on pin 10 (OSCO). That's all I want to see. I get the signal I have attached. What is the problem? Have I got my config bits wrong?
Rich (BB code):
#include <p24F16KA102.h>
// Configuration Bits - see p24F16KA102.h
_FOSCSEL(FNOSC_FRCPLL & IESO_OFF); // Fast RC Oscillator With Postscaler (FRCDIV)
_FOSC (OSCIOFNC_OFF & POSCMOD_EC); // OSCO Pin Has Clock Out Function (CLKO), External clock
_FWDT (FWDTEN_OFF); // WDT off
//main loop
int main(void)
//Set up Clock
OSCCON = 0x11C0; //select INTERNAL RC, Post Scale PPL //Fast RC Oscillator with Postscaler and PLL module (FRCPLL)
//Loop forever
while(1)
