simple problem about nodal analysis
Discussion in 'Homework Help' started by PG1995, May 11, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi, :)
    Almost all the details you will find in the given link below:
    http://img710.imageshack.us/img710/1565/exampleproblemnodalysis.jpg
    You will find the expected (or, target answers) in the top right corner.
    As you can see my value for V1 is utterly wrong. It should have been 37.818V according to the answer given in the book. I have checked my equations several times but I found nothing wrong with them. Please help me with it. Many thanks for your help.
    Cheers
  2. Jony130
    Feb 17, 2009
    3,995
    1,117
    Your have a error in equation for node V2
    I3 = I2 + 2A = V1/4 - V2/4 + 2 = V2/10 this is correct, but after that your simplification is incorrect.
    I get this for node 2
    5V1 - 7V2 = - 40
  3. PG1995
    Apr 15, 2011
    753
    5
    Thanks a lot, Jony.
    I multiplied the above equation by "40". I don't see any error. What am I missing? 10V1 - 10V2 + 80 = 4V2 => 10V1 - 14V2 = -80.
    Please guide me. Thanks.
  4. Jony130
    Feb 17, 2009
    3,995
    1,117
    Oops I didn't note this.
    So your equation are correct.
    I use this site to solve this for me
    http://www.wolframalpha.com/input/?i=solve+for+V1++,+3V1+-+2V2+=+48+,+10V1+-+14V2+=+-+80+
    And I get
    V1 = 416/11 = 37.8181818V
    V2 = 360/11 = 32.7272727V
    For this equation
    3V1 - 2V2 = 48
    10V1 - 14V2 = - 80
  5. PG1995
    Apr 15, 2011
    753
    5
    Once again, many thanks Jony.
    I made a very silly mistake at the end. While applying Cramer's rule I had incorrectly used "-4" instead of "-14". This was the reason for all the error. I just noticed it now :(. You are really nice.
    Best regards
    PG
