Simple passive audio summing
Discussion in 'The Projects Forum' started by guitarguy12387, Dec 20, 2009.
  1. guitarguy12387
    Thread Starter Active Member
    Apr 10, 2008
    359
    12
    Hey everyone. I simply want to sum a balanced stereo signal to balanced mono. Not sure how best to go about it! Any tips? Thanks!
  2. DickCappels
    Aug 21, 2008
    2,753
    665
    Assuming that you are talking about the audio input to an amplifier:
    Connect one 1k resistor to the right channel. Connect one 1k resistor to the left channel. Connect the other end of both resistors together and that is the mono output. All shields (grounds) are connected together.
    Or do you want to connect the outputs of two amplifiers to drive one speaker? (I don't know how to do that safely, but I'll bet somebody does).
  3. kubeek
    Sep 20, 2005
    4,687
    805
    He´s talking about balanced signal. Probably he wants to keep it balanced
  4. guitarguy12387
    Apr 10, 2008
    359
    12
    Yes i am looking to keep it balanced. Could i just do this twice (i.e. sum the hot pins together then the cold)?
    What i want to do is more for mixing purposes than for an amplifier... simply, i want a button that i'll press that will sum a signal to mono. Sorry, shoulda been more clear.
  5. DickCappels
    Aug 21, 2008
    2,753
    665
    That should work (two mixers instead of one). It only takes four resistors to try!
