simple oscillator?
Discussion in 'General Electronics Chat' started by Lem0nHead, Oct 27, 2010.
  1. Lem0nHead
    May 4, 2009
    hello
    I need a 38 kHz square-wave generator (for an IR LED), but it needs to generate the 38 kHz square-wave for 1ms, and stop generating (LOW) for 1ms
    I can't use too many components/routes (the single layer board must have at most 16mm/0.6inches width)
    I guess a microcontroller would probably be a good idea, but is it possible to do that with a few resistors/capacitors using a 556 as schmitt trigger (or even a 74c14/similar)?
    thanks
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I guess you could use a 556, and the reset pin on the 38 HHz osc to gate the signal
  3. Lem0nHead
    May 4, 2009
    yes, but I guess I'd need enough components that wouldn't fit on a 0.6inches single-layer board
    for instance, I tried to do that: [​IMG]
    (got it from http://forum.allaboutcircuits.com/showthread.php?t=26272&page=2 ), and it gets wider than 1 inche
  4. t06afre
    May 11, 2009
    5,939
    1,222
    I guess then a 8 or 6 pin micro would be the best. Many of them come with internal osc. So you will only need the chip and a 100nF decoupling cap.
  5. Markd77
    Sep 7, 2009
    2,803
    594
