Hi, just registered here, and I am in need of help with this review problem. I transferred schools and the school that I came from they taught about the Norton Analysis but not when the voltage sources were in parallel. I observed the example problem on this site but the only difference is there is another voltage source below the load resistor, so I only need the equation to find the current through r1 and r2, I can do everything else. So again its like the basic norton problem but with three voltage sources instead of two, one below the load resistor.
Heres the link:
http://www.allaboutcircuits.com/vol_1/chpt_10/9.html
Thank you
Heres the link:
Thank you
