Simple Multiple Choice ?...Please let me know if I'm right, Thanks!
Discussion in 'Homework Help' started by ElecTechCan, Jul 4, 2010.
  1. ElecTechCan
    Jun 26, 2010
    6
    a single phase 1HP motor consumes 9A at supply voltage of 123V at 60Hz at a power factor of 78% while driving a fan. Which of the following statements is true?
    a) The motor is overloaded
    b) The motor is not overloaded
    c) The motor is operating at 50% efficiency
    d) The speed of the motor is 3600 rpm
    I think the answer is A. I don't think it can be C because the numbers I came out with suggest it's operating above it's 1HP capacity? I don't think it can be D because there's no mention of the # of poles so I don't even know how you would calculate the rpm...
    Please let me know if I'm right or help steer me in the right direction, Thanks!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I'd agree with answer (a) for the following reason ....
    1HP=746W
    At 123V supply and pf=0.78
    Iload(rated)=746/(123*0.78)=7.8A
    So at Iload=9A, the rated current is being exceeded which suggests an overload condition.
