I'm a mechanical engineer working on designing a simple time delay circuit for a DC motor. I took a stab a designing the circuit and the image is attached. I'd like it to work as follows: When the switch is closed, a small amount of current goes through to the timer. After the time is up, a standard 4 post relay is activated and the motor turns on for some time - 5 seconds or so. After that time the switch opens and the timer resets. The circuit is to launch a projectile which will depress the switch. When it launches, it will open the switch. The timer I plan to use is here: http://ics-timers.com/pdfile/interval.pdf
I have a couple of questions: Most important - will this work as I described? And the motor lists a stall amperage. Should there be enough power for the stall, or just enough to operator normally? Thanks for any help and suggestions.
