Simple Motor that moves treds
Discussion in 'The Projects Forum' started by doveroh, Feb 26, 2012.
  1. doveroh
    Feb 26, 2012
    I am brand new here and just starting to learn about circuits and electronics. I have a photo printer that sits flat and I want to make a battery powered system that takes a printed picture (it will fall onto tracks) (thinking like robot treds like on dozers) and move it to fall off at the end.
    Any suggestions on where to start. It needs to move about 6"
    Thanks.
    Jesse
  2. #12
    Nov 30, 2010
    16,665
    7,310
    Start with a mechanism that has treads, add a motor that is strong enough to move them, than decide on what shall cause the motor to start and stop.
  3. Nicholas K. Heinrich
    Member
    Feb 25, 2012
    61
    After you have accomplished what #12 has said, you could time how long it takes a page to print out, and have a restart timer set to run the tread for that long plus about 5 seconds. You could possibly use some sort of optical sensor that senses the paper in the light path, and acts as the trigger on the restart timer. Here is an example of a restart timer. The optical sensor would replace the momentary pushbutton switch on this model. http://www.canakit.com/restart-timer-kit-ck197-uk197.html
  4. doveroh
    Feb 26, 2012
    Thanks for the great ideas, Any good places to purchase a tread that you would suggest.
    I was thinking since the pictures only print when people get their picture taken. I could use a sensor to trigger the mech. Any good inexpensive ones to suggest.
    I am very new to this and looking for places to pick up inexpensive, but good quality.
    Thanks again,
    Jesse
  5. #12
    Nov 30, 2010
    16,665
    7,310
    Getting a photo taken suggests a flash of light. That could be sensed to start a motor.
    Start with a photo-transistor, then a 555 chip to a triac to run an AC motor for a set amount of time. Using a 556 chip could add a delay before the motor starts.
  6. djsfantasi
    Apr 11, 2010
    2,900
    875
  7. mcgyvr
    Oct 15, 2009
    4,787
    973
    Why not just keep the tread always moving.. No need to worry about starting/stopping/sensors,etc..
  8. doveroh
    Feb 26, 2012
    That's a good idea. I think I will keep the treads moving. The more I think about it even rubber bands on wheels would work to move it. It only has to move about 6".
    Could I hook a power supply straight to the motor or do you suggest something else?
  9. #12
    Nov 30, 2010
    16,665
    7,310
    Read the label on the motor. If it says, "continuous use" you can connect the power directly to it and use it continuously.
