Simple Logic Inverter
Discussion in 'The Projects Forum' started by chrisw1990, Apr 16, 2012.
  1. chrisw1990
    Thread Starter Active Member
    Oct 22, 2011
    543
    41
    I need to implement a simple logic inverter..
    iv found here a simple one using n-channel and p-channel mosfets, but is there an easier way?
  2. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    CD4049, CD4069, CD40106 for voltage up to 15V, 74HC14 for voltages up to 5V
  3. chrisw1990
    Oct 22, 2011
    543
    41
    i need a small chip.. i made a hardware error on a project, i can fix with one mosfet, but im trying to find extremely small (passive?) solution.. so no ics
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    One NFET and one pullup resistor on its output (Drain) is all you need. :)
    chrisw1990 likes this.
  5. chrisw1990
    Oct 22, 2011
    543
    41
    so.. my picture, withthe pchannel replaced by a resistor?
    and is that a weak or strong pull up?
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I'm not going to another site to see your picture.
    You need a NFET;
    The input is the Gate (and is driven from your original logic output).
    The Drain is the output and needs a pullup resistor to Vdd.
    The source is ground (Vss).
    The pullup resistor depends on the speed you need it to work at, if it works at higher frequencies the resistor should be smaller. Generally 470ohm or 1k will work for most apps.
  7. chrisw1990
    Oct 22, 2011
    543
    41
    ah yeh ok (note to self post pictures not links) i tell other people to, dunno why i didnt think of it..
    yeh i get the circuit now, just wanted to make sure it was how i thought..
    ill post the image up for any googlers or future readers.
  8. MrChips
    Oct 2, 2009
    12,623
    3,451
    2N2222 NPN transistor, 1KΩ resistor in series with the base and 10KΩ pull-up load resistor at the collector.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    Not all inverters are created equal. The application may dictate the design. What will it be used for?
  10. chrisw1990
    Oct 22, 2011
    543
    41
    just to invert the logic for a mosfet switch =] sadly i cant change the polarity of the trigger, it is active high, and my circuits switch is active low.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    I hope you are going to put it in front of the driver.
    What is the MOSFET driver? Is it an IC, or is it discrete? Give us a part number, or a schematic (preferred).
    How fast does it have to switch?
    What is the minimum pulse width?
  12. chrisw1990
    Oct 22, 2011
    543
    41
    sorry "in front of the driver"?
    no sorry when i said mosfet switch.. its a p-channel mosfet, acting as a switch, its a bodge to correct a prototype circuit, but the pin it would be driven by is active high auto controlled by the pic32 im using.
    it doesnt have to switch fast, its just an on/off style switch.. power on, power off.. i just needed to invert the polarity to make sure it worked correctly.
  13. Ron H
    Apr 14, 2005
    7,050
    657
    Why can't you change the polarity coming out of the PIC32? Don't you have control of the software?
    I hope you are using a logic level MOSFET. Otherwise, it won't work.
  14. chrisw1990
    Oct 22, 2011
    543
    41
    its a USB library function controlling the bus voltage :)
    and sorry probably a terminology thing.. "logic level mosfet" i.e. triggerable by logic levels?
  15. Ron H
    Apr 14, 2005
    7,050
    657
    Yes. Rds(on) needs to be specified at or below 5V Vgs. If it isn't the MOSFET may turn on weakly, and the on resistance may be too high
  16. chrisw1990
    Oct 22, 2011
    543
    41
    4.5V :D phew! id only looked at the threshold voltage..:)
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    The threshold voltage spec for a Mosfet is when it is almost turned off. Don't you want it to be turned on very well?
  18. Ron H
    Apr 14, 2005
    7,050
    657
    I think he means that the device is spec'ed for Rds(on) at Vgs=-4.5V, i.e., it's a logic level device.
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    He said he looked at the "off" threshold voltage.
    An IRL540 has a threshold voltage of 1V to 2V when it is almost turned off with a current of only 0.25mA. Its is spec'd to be turned on very well with a max on-resistance of only 0.058 ohms when its gate voltage is 5.0V.
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
