Simple LM1086CT-3.3 check
Discussion in 'The Projects Forum' started by OldSkoolEffects, Sep 18, 2013.
  1. OldSkoolEffects
    Nov 18, 2009
    68
    I've not used a LM1086 before, but was attracted by the low dropout and just wanted to make sure I'm going about it correctly. I want to be able to use a wide range of voltages, like 7-24 but keep noise to a minimum.
    V+ will be used to power an op-amp in the future, so I'm hoping the decoupling I have on the input of the LM1086 along with decoupling on the op-amp will isolate any noise issues.
    Any advice would be appreciated!
  2. Dodgydave
    Jun 22, 2012
    5,148
    769
    yep looks ok to me...
    lm1086
  3. #12
    Nov 30, 2010
    16,671
    7,319
    The data sheet says to use 50 uf aluminum for the output or 10 uf tantalum.
