Simple Light Sensor
grplnxprt
Joined Jun 6, 2015
9
I'm trying to make a simple light sensor. Just a AAA battery, a 5mm LED, and light sensor.
I bought some ambient light sensors from Radio Shack and made it work.
I bought some LDRs online and it's not working with one of them in place of the ambient light sensor.
The LED I'm using:
"E-Projects - Clear Yellow / Amber 5mm LED - Wide Angle Light"
Clear Yellow/Amber 5mm LEDs - Wide Angle Light
Max Current: 20mA
Forward Voltage: 1.8 - 2.1
Max Reverse Current: 10mA
Power Angle (deg): 160 - 180
MCD: 4000 - 5000
The LDR I'm using:
"Photo Light Sensitive Resistor Photoresistor Optoresistor 5mm GM55399 5539"
Maximum Voltage: 150 Volt DC
Maximum Wattage: 100mW
Operating Temperature: -30 ~ +70 deg C
Spectral Peak: 540nm
Light Resistance (10 Lux): 50-100 Kohm
The battery I'm using:
Radio Shack AAA
Again, it worked with a 5mm ambient light sensor I bought from Radio Shack, but not with the LDR.
I watched a video of somebody doing this, but his LDR was bigger than mine.
I'm completely new to this. If I'm leaving out important information, please let me know.
I'm open to using any other suggested components. I just need the LED to turn on when light hits the sensor and turn off when the sensor is covered.
Any help is greatly appreciated. Thank.
cornishlad
Joined Jul 31, 2013
242
Radio Shack AAA
[/QUOTE]
I'm a bit surprised the led light at all with only 1.5v.
Try again with 2 x aaa (3v)
bertus
Joined Apr 5, 2008
22,276
Can you provide a schematic of the current set-up?
You can upload a schematic using the "Upload a File" button.
Bertus
grplnxprt
Joined Jun 6, 2015
9
Bertus, I tried figuring out how to draw a schematic. I'm afraid it's a bit over my head at this point.
I can describe it and hope that works. It's pretty basic.
Battery positive goes to light sensor.
Light sensor goes to LED.
LED goes to battery negative.
When the light sensor is the ambient light sensor it works.
When I substitute the LDR in it's place, it doesn't work.
I hope this helps.
grplnxprt
Joined Jun 6, 2015
9
Alright...
I bought a 9v battery and a resistor.
I hooked them up and got the LDR to light.
But, it behaves just like the ambient light sensor.
It's brighter depending on the amount of light present.
I want the LED 100% on when there is light and 100% off when there isn't.
Anybody?
Thanks again.
Bernard
Joined Aug 7, 2008
5,784
Can you measure your LDR with different light conditions. Different LDRs vary wildly in specs.
Examples: Bright window, ambient, & dark,
2k, 10k, 1M
7k, 38k, 1M
50, 130, 10k
1.2k 7k, 200k
grplnxprt
Joined Jun 6, 2015
9
Bernard,
I had to Google how to measure it. It says to use a multimeter. I don't have a multimeter. I can gain access to one Monday.
Is there a certain measurement I'm hoping for? If so, can I just find LDRs online that fit that criteria and buy them?
grplnxprt
Joined Jun 6, 2015
9
Thanks for all the replies.
What I'd really like is for somebody to tell me in laymen's terms how to make this.
I need a simple circuit that fully lights an LED when there is light present and turns it off when there isn't.
The simpler, the better.
Bernard
Joined Aug 7, 2008
5,784
With comparator, just about any LDR will work; with a choice , would pick a mid range around 10k. LM393N is fairly common if available to you.It is late, back Monday.
grplnxprt
Joined Jun 6, 2015
9
cornishlad - Thanks. I'll check it out,
RodneyB - Thanks. I'll check it out.
AnalogKid -
  • Model: 2760325
  • Catalog #: 2760325
RADIOSHACK® 3MM AMBIENT LIGHT SENSORS
ErnieM
Joined Apr 24, 2011
8,377
If you go thru the user's comments on RS site someone linked to the data sheet. It's an Everlight ALS-PTP144-6C/L451. At first glance it is not suitable for this project as it will only pass a few milliamps at full brightness when there is 5V across it.
Seems the good old CDs cells are now banned by the ROHS directives. I don't have any good alternatives to offer that you can get at Radio Shack.
