Simple LED with timer on PIC18 C18 Compiler
Discussion in 'Embedded Systems and Microcontrollers' started by skybox, Jul 28, 2009.
  1. skybox
    Thread Starter Active Member
    Mar 2, 2009
    68
    Hi guys,
    I can't get this to work. I am using the internal oscillator at 31 kHz and have a prescale value of 1:128 with the 8-bit timer. If I did my math right, this should take about 4 seconds for the timer interrupt flag to recieve a 1 after overflow. If someone can give me tips and/or advice, it would be greatly appreicated!!!
    Thanks!
    Here is my code:
    Code ( (Unknown Language)):
    1.
    2. #include <p18f14k50.h>
    3.
    4. //pragma codes
    5. #pragma code high_vector=0x08
    6. #pragma config FOSC = IRC //enable the internal oscillator
    7.
    8.
    9.
    10.
    11. //function prototypes
    12. void oscillator(void);
    13. void timer(void);
    14. void high_isr(void);
    15.
    16. void interrupt_at_high_vector(void)
    17. {
    18.    _asm goto high_isr _endasm
    19. }
    20.
    21. /*******Oscillator function - This function will set the oscillator to 31 kHz***********/
    22. void oscillator(void)
    23. {
    24. //Set oscillator to 31 kHz
    25. OSCCONbits.IRCF2 = 0;
    26. OSCCONbits.IRCF1 = 0;
    27. OSCCONbits.IRCF0 = 0;
    28.
    29. //Device clock derived directly from the LFINTOSC internal oscillator
    30. OSCTUNEbits.INTSRC = 0;
    31. }
    32. /*******End Oscillator Function********************************************************/
    33.
    34.
    35. /*******Timer function - Will start the timer and set pre-scalar to 1:128**********/
    36. void timer(void)
    37. {
    38. //Pre-scalar value of 1:128. This should give about 4 seconds for the timer0 interrupt flag to go high
    39. T0CONbits.T0PS2 = 1;
    40. T0CONbits.T0PS1 = 1;
    41. T0CONbits.T0PS0 = 0;
    42.
    43. T0CONbits.TMR0ON = 1; //Enables Timer0
    44. }
    45. /*******End Timer Function********************************************************/
    46.
    47. void main(void)
    48. {
    49.         INTCONbits.GIE = 1; //enable high priority global interrupts
    50.         RCONbits.IPEN = 1; //enable priority levels on interrupts
    51.
    52.         INTCONbits.TMR0IF = 0; //clears timer interrupt flag
    53.         INTCONbits.TMR0IE = 1; //enable Timer0 interrupt bit
    54.         T0CONbits.T08BIT = 1; //Set Timer0 as an 8-bit timer
    55.         INTCON2bits.TMR0IP = 1; //Timer0 Interrupt bit set to high priority
    56.
    57.         TRISC = 0x00; //set all PORTC bits as an output
    58.
    59.         oscillator();
    60.         timer();
    61. }
    62.
    63.
    64. //High Interrupt Vector function
    65. #pragma interrupt high_isr            // declare function as high priority isr
    66. void high_isr(void)
    67. {
    68.     if(INTCONbits.TMR0IF = 1)
    69.         {
    70.             LATCbits.LATC0=1 //Turn on LED at RC0
    71.         }
    72. }
    73.
