simple LED with delayed start
Discussion in 'The Projects Forum' started by miha_s, Oct 29, 2014.
  1. miha_s
    Oct 29, 2014
    Hi everyone! I am a newbie in the world of electronics and would like to construct a simple circuit and would like to ask you for some help and advice.
    I would like to build a very simple circuit with a LED light, a battery, ON/OFF switch and what else is necessary. The idea is when you turn it on, the light is off for the first week and starts blinking only in the second week.
    Is it possible to do it and how would you do it?
    Thank you very much for any advice :)
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    How accurate does the time keeping need to be?
  3. ScottWang
    Aug 23, 2012
    4,934
    777
    1. What kind of the power supply?
    2. How about the V/I of the power supply?
    3. How about the V/I of led?
    4. How many leds do you like to use?
    5. Do you need the 7-segments led display?
    6. Turn on the switch, leds are off.
    7. Delay for a week. (accurate)
    8. The leds are blinking. (frequency?)
    9. How does the next step?
    a) How long do the leds still keep blinking?
    b) And the next?
    10. And some other things else?
  4. wayneh
    Sep 9, 2010
    12,403
    3,251
    Is your goal the end product or the fun of constructing it? I ask because it may be easier to use off-the-shelf components to do this project. Like a lamp timer controlling a flashing LED.
  5. Bernard
    Aug 7, 2008
    4,248
    423
    For simple, could try 4060, 4040, C555 & FET driver for LED. Accuracy maybe a hour or so in a week. First week power drain about 10 mA h, second week 1.7 Ah, so 4 AA NiMh batteries ??
    ? where did this cross out line come from??
  6. BobTPH
    Jun 5, 2013
    807
    121
    It you want any accuracy, a microcontroller with a crystal would be the simplest way.
    Bob
  7. djsfantasi
    Apr 11, 2010
    2,913
    881
    Don't know what you are using as an editor, but your post has strikeout HTML tags embedded in it. I tried a variety of key combinations, but only [ s ]Text[ / s ] worked
    Bernard likes this.
  8. miha_s
    Oct 29, 2014
    Dear all, thank you very much for all your useful information! At least now I know in which direction to proceed... Yes, maybe should explain some details:
    - in general thought of batteries, such as xr2032 3V or something similar
    - the idea is that the blinking light would remind my grandpa to check in the fridge for any food going bad. When he checks, then he turns off the device.
    - the accuracy isn't that important, also a day up or down does not change much things.
    Thank very very much again!
  9. djsfantasi
    Apr 11, 2010
    2,913
    881
    Just a couple of ideas.
    A purely hardware solution would take a clock (555), feeding cascaded counters (such as the 74HC4059 presettable counter) to count for a long time - week, and a flip flop/latch to latch the output.
    If you are comfortable with microprocessors, a small one could be programmed to count for a week, timer interrupts/overflow, and turn your LED on. This would result in a small package with few parts.
  10. wayneh
    Sep 9, 2010
    12,403
    3,251
    How about a magnet on the fridge calendar? I'm just saying there might be some other solutions.
  11. BobTPH
    Jun 5, 2013
    807
    121
    Usually, my nose is the only thing I need to remind me of that!
    Bob
  12. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Something like this, if you don't want to go the microprocessor route?
    Edit: Schematic and .asc file revised
    absf likes this.
  13. djsfantasi
    Apr 11, 2010
    2,913
    881
    Thanks! I couldn't for the life of me remember the part number nor name of the 14 stage ripple counter
  14. Bernard
    Aug 7, 2008
    4,248
    423
    Just filling in the numbers from post # 5. I used a 3.3k R & red LED to monitor times. Stage 12 of 4060 = 147.6 sec. or 2 m+ 27.6 sec. Adjusted R3, 30k pot to give this time. Note that R2 + R3 = 160k, when measured = 179k with pot at about 20k. Only 4060 breadboarded. pin 3, 555 might need to go to Q11, pin 15, 4020 to release reset on 555 at count 16777216. Pulse # 2 00001.jpg
    You can use an AC adapter, 4.5 V to 6V, or batteries.
    absf likes this.
  15. miha_s
    Oct 29, 2014
    oh thank you very much for your help!
