Simple Karnaugh Map Question
Discussion in 'Homework Help' started by jegues, Dec 9, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    I'm confused about an aspect of Karnaugh maps.
    When we have a map like indicated in the figure attached, how do we group appropriately?
    I've always tried to group every 0 in the largest group possible, regardless whether or not the other 0's in the same group have been grouped already.
    This will create redundant terms, correct?
    How do I identify this and eliminate them?
    The expression I come up with, with my groupings is,
    (x_{2} + x_{0})(x_{2} + x_{1})( \bar{x_{3}} + x_{0})(x_{1} + \bar{x_{0}} + x_{3})
    Thanks again!
      File size:
      177.3 KB
      25
  2. blah2222
    May 3, 2010
    565
    33
    That's fine, might be more intuitive to do the Sum of Products (all the 1's, if the blanks are all 1's with no don't cares).
    F = x1x0 + x0'x2x3' + x0x2x3
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    If you group the 1s (assuming that they are the rest of the squares), you need only 3 groups with less overlay, but with smaller groups.
    I don't think overlaying hurts. If I grouped the 0s I would do it the same way you did.
  4. zgozvrm
    Member
    Oct 24, 2009
    115
    That's correct! You want to get the fewest number of groups that contain all the 0's (or 1's). If a "straggler" can be grouped in a small group or a large group, use the large group.
