Simple idea, hard to do?
Discussion in 'General Electronics Chat' started by Ryder Spearmann, Feb 13, 2010.
  1. Ryder Spearmann
    Feb 13, 2010
    I have a drum pedal with a simple microswitch.
    Nothing mechanical about the pedal can be changed.
    I need to electronically delay the action of the switch by about 20 milliseconds.
    It would be even better if I could adjust it in the 0 to 100 ms range or so.
    Can a simple RC circuit do this?
    I have no power supply, nor a ground, only what appears on the line to the switch, so the solution has to be rather passive.
    Thank you!
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    It would take a "powered" circuit to do this right. A 555 timer chip could do this, and a pot can make it adjustable, but you will need a 9V battery, or a plug-in wall wart.
  3. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    Questions:
    1. What bias voltage is being fed to the switch when it is open?
    2. What is the current draw when the switch is closed?
    3. Once you have a 20mS turn-on delay, does it matter what the turn-off delay is?
    Nothing is ever simple... accept nothing.
