Simple Headlight Wiring Problem
Discussion in 'The Projects Forum' started by liamstears, Dec 21, 2013.
Thread Status:
Not open for further replies.
  1. liamstears
    Jan 31, 2013
    Just need a little help
    Basically I'm adding 2 spotlights to my motorcycle and rewiring my headlight and the spotlights to run from a direct feed from the battery (the headlight feed wiring cant cope with the draw)
    Problem I got is that I want 1 spot light on with my low beam but then both spotlights on with my high beam but keeping the low beam feed to the headlight off
    I have attached a pictured of the wiring setup idea and need someone to point out how I could get the desired effect written above. Im guessing some sort of diode setup but would I need something special to cope with the amps? The spots only draw around 10w/0.9a but the headlight is 45w/3.75a
    Thanks in advance for any help
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    Sorry, but automotive modification discussions are not allowed here.
  3. liamstears
    Jan 31, 2013
    Really? Why?
    All about circuits but I cant discuss my circuit? lol
  4. BillB3857
    Feb 28, 2009
    2,402
    348
  5. dmshropshire
    Member
    Dec 1, 2013
    33
    6
    What if you just reworded this whole thing with out the use of the word motorcycle?? Or headlight perhaps. Abandon this one and start over...
  6. tshuck
    Oct 18, 2012
    3,531
    675
    The moderators are not stupid....
    A circuit where wiring it wrong could violate local traffic laws, yes. A circuit that could easily get you killed, yes. This rule is in place to protect everyone - members of the forum included.
  7. dmshropshire
    Member
    Dec 1, 2013
    33
    6
    I did not intend to say they were. Was merely suggesting a way to get help. Also did not realize this was a safety matter. This now makes total sense, I did not catch that in the link above. My apologies
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    bertus
Thread Status:
