Hi!
I'm trying to make the two outputs (Q and /Q) of a D-type flip flop step from high to low, alternating with each other, with every rising edge of a squarewave input (ie a simple switch going to ground). I've never used flip flops before and I'm having real trouble getting it to work!
Attached is the circuit diagram I'm trying.... Have I connected it right?? Any advice is much appreciated!
The two outputs (Q and /Q) will work JFET gates on two audio outputs, so with the flick of a non-latching switch you can step between 'A' output and 'B'.
