simple first project
Discussion in 'The Projects Forum' started by sailingboarder, Jan 25, 2008.
  1. sailingboarder
    Jan 25, 2008
    12
    so i am working on a open-ended project for school, and its my first foray into electronics
    for our specific project, we want to control two motors, each multi-dimensional, so four total movements
    we want them to happen in a controlled order, specifically close-in-out-open-close-in-out-open-etc.
    we would like to trigger each movement by the conclusion of the previous movement
    while we have figured out a way to make each motor switch direction, we have had a hard time making one motor start the other motor at the same time as stopping itself
    i thought about using some sort of IC that could trigger the different flows instead of manually turning flows on and off, but i do not know if/how to do this
    i stumbled upon the L298N motor chip, but i'm not sure if this is really what i need and if so, how to use it
    any advice on where to look for information would greatly be appreciated
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Can you post a schematic of what you have so far?
    What kind of motors, DC or stepper?
    Are they linear or rotary?
    What's the voltage and current rating of the motors?
    The L298 is an H-bridge driver IC. It's much easier to use if you also use the L297, but you'll still need a microcontroller or logic circuit to drive the L297.
    If your motors are pretty low power, they can be driven using less complicated circuitry.
  3. sailingboarder
    Jan 25, 2008
    12
    we really don't have much at the moment, we are simply brainstorming ways to approach the problem
    as far as a motor, we have one right now and will probably get another one of the same kind
    we just bought an electronic screwdriver and ripped the casing off it so we can use the motor
    its 3.6V
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    So are you planning on having this motor rotate a disk, turn a screw, swing a boom?
    Since it is purely a 3.6V DC motor, you won't need very complex electronics like you would with a stepper motor.
    Basically, you will have two motors, each capable of running in forward direction, reverse direction, or stopped, right?
    What kind of motion did you have in mind?
  5. sailingboarder
    Jan 25, 2008
    12
    we want to open and close a clamp, and then move that clamp back and forth along a track
    basically, we are automatically loading pencils into an automatic pencil sharpener
    i revised our design using dpdt switches/relays
    the thing i'm having trouble understanding about the relays is this: can i flip the relays with a current pulse, or does it have to be a constant flow of power?
    i'm attaching a draft schematic, but without a way to flip the switches
  6. scubasteve_911
    Dec 27, 2007
    1,202
    What is going to monitor and control the sharpening time? Switches and relays are nearly instantanious. If you aim for a neat automatic way to sharpen pencils, then you pretty much need a method to program a process in. If you are new to electronics, you might look into a basic stamp or maybe a PLC if you can borrow one.
    Steve
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Ahh, OK. :)
    Wow, that blue on the black background is hard to see!
    Yes, the reversal switch will work - but you need to stop the motor(s) for various periods of time while either the other motor is running, or until the sharpener is done with the pencil. Some sharpeners show a light when the pencil is sharp - are you planning on using that feature?
    Usually, relays have solenoids that are either energized to close the NO contacts and open the NC contacts, or de-energized to open the NO contacts and close the NC contacts. There are latching relays, but they're pretty expensive.
    What you seem to need now are SPDT limit switches to cause one motor to stop running and the other to start running, or engage the next action in the sequence.
    You also need a way to determine when to stop the thing - like there are no more pencils left to sharpen.
  8. sailingboarder
    Jan 25, 2008
    12
    so i've decided that we basically will just want continued motion, then i will simply set one throw of each relay to be powered when no flow through the coil and the other when there is flow through the coil, which will be alot easier than latching switches
    also, i though about using a push button switch that can be pushed when the motion reaches the end of its path, like the clamp reaching the top, and it would turn on the flow that would then reverse the motion
    as far as the light on the pencil sharpener is concerned, the one i have right now does not have that, but i am going out to see if i can find one at office depot - how would i use that light to send a flow to the coil on one of the relays?
    thanks for all your help, i can see the project design starting to fall into place
  9. sailingboarder
    Jan 25, 2008
    12
    after a trip to office depot, i did not find a pencil sharpener with a light when finished, but i did find a pencil sharpener that has a sensor and will automatically shut off when the pencil is sharp
    is there a way to capture this action and use it to supple power to one of the relays?
    other than that, i think i i've figured out how i'm gonna make the thing work, electrically
    this afternoon we're gonna start building the frame while we finalize our circuitry design
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    As far as the auto-shutoff feature of the sharpener, I haven't seen one that does that.
    Opening up such an appliance will:
    1) Expose you to hazardous line-level voltages
    2) Void the warranty.
    How much power does it use when it's operating?
    [eta]
    Just found this one:
    http://www.officedepot.com/a/products/517304/Cordless-Pencil-Sharpener-Black/
    Battery powered - runs off four AA cells (6v) auto start, auto shutoff, for under seven bucks. Sounds like just what you need.
    What are you using for a power supply? A converted ATX-form factor computer supply? If so, you'd have 12v available, along with +/-5V. I have a sneaky way to get a TTL/CMOS-compatible signal out of this sharpener by using the attached circuit.
  11. sailingboarder
    Jan 25, 2008
    12
    the sharpener? i do not know, we decided to skip that one and simply push the pencil all the way in slowly, then pull it out, keeping things simple
  12. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    If you can put a relay coil in parallel with the sharpener motor, it will de-energize when the motor stops. Whether such configuration is possible depends on motor voltage and the relays available to you.
    Always exercise caution when dealing with electricity. Don't go exploring while the thing is plugged in.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See my prior post; I added some interesting things to it ;)
