I want to build a circuit to take the high current off the single point that currently connects one leg of the primary winding of the ignition coil to chassis ground. The other side of the primary goes to +12vdc. The secondary is NOT connected to the primary at one side as they sometimes are. There are two spark plugs in this 2 cylinder engine. One side of the secondary goes to one plug and the other side goes to the other plug. Both plugs fire simultaneously with the circuit completed through the engine block but each cylinder burns on every other spark. There is a capacitor across the point.
One constraint for the desired circuit is that one side of the point is unavoidably connected to battery ground. The other side, of course, should trigger the circuit.
One question is "capacitor discharge" circuit or direct battery current through the circuit and primary? Pros, cons, and recommendations please!
I don't have any SCR's at the moment but I suppose that would be an ideal switch.
I do, however, have a few triac's that, I think, could be used. They have a maximum gate current of 50 milli amps and are rated at 600v and 12 amps. OK guys and gals, what do you suggest as a simple circuit. I don't think any timing adjustment would be required. Right now, a cam on the cam shaft operates the point and all I can do is set the gap and it works fine. Parts can be hard to find for this old engine so I would like to preserve the currently pristine point. Thanks Ed
