I'm a total newbie when it comes to all things to do with electricity. I'm interested in doing an electrolysis project for fun, and need some advice.
I have a 12V 10A battery charger. I have a pail of water mixed with some chemicals to improve conductivity. I have a 5 pieces of metal, 1 is a piece I want to derust, and 4 are the sacrificial metals. I need 4 sacrificial pieces because this operation is line of sight, meaning the surface to be derusted has to be in direct line of sight with the sacrificial piece.
Here's the plan.
1) First I place the 4 sacrificial pieces on the edge of the pail, one each in the N, S, E and W positions.
2) I place the piece to be cleaned in the centre of the pail without touching any of the other pieces.
3) I take the negative cable of the charger and connect it to the piece I want to clean.
4) I take the positive cable and clamp it to one of the sacrificial pieces, say the one on the N position.
5) I use several small wires with crocodile clips on both ends, to connect the sacrificial piece in the N position to those in the E, S and W positions.
Question:
How thick does the wires I use in (5), the small pieces with crocodile clips at both ends, need to be?
The charger can hit 10A max, and the pieces of wire I bought are the normal kind used for electronics stuff. Will it totally burn through the wire?
If yes, any ideas for connecting up the 4 sacrificial pieces electrically in a safe way?
Thanks!
Here's the plan.
Question:
Thanks!
