Simple diode circuit help
Discussion in 'General Electronics Chat' started by roybk, Aug 23, 2011.
  1. roybk
    Aug 23, 2011
    Excuse me, my circuit skills just got rusty.
    Can anyone please give me a clue what would the voltage rating be at the purple node? appreciated!
    R.
      File size:
      24 KB
      43
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's a datasheet for the BAV99; a dual diode:
    http://www.fairchildsemi.com/ds/BA/BAV99.pdf
    It's being used as a clamp to limit the voltage excursions above and below ground.
    The AUTO_IN - whatever that is - limits the current through either diode in the BAV99 in case the signal goes above 5v or below ground. The clamp at low current values (1mA) is the positive supply +~.7v to ground - ~0.7v
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Do you mean voltage rating or range?
    Presumably input AUTO_IN can have a somewhat unspecified range (within limits). This bit of circuitry seems to be designed to ensure the volatge at the node in question does not go outside the nominal range of 0 to 5V.
    The two diodes are orientated & biased to achieve that outcome.
  4. Adjuster
    Dec 26, 2010
    2,147
    300
  5. AdyCh
    Aug 20, 2011
    That voltage at that point, if we assume the fvd of diode 0.7V, will not be less than -0.7V and greater than +4.3V
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Greater than 5V+Vf ..... The node has to climb over 5V to get the top diode forward biased.
  7. Adjuster
    Dec 26, 2010
    2,147
    300
    An important point, that last. When adding diodes like this e.g. to protect an IC, it may be difficult to keep to safe voltages, which are often just a few hundred mV beyond the rails. Using Schottky devices may help, as may putting series elements between the big diodes and the device - the latter strictly restrain the current rather than the voltage.
  8. AdyCh
    Aug 20, 2011
    Correct. Yes it must be 5+Vd . Didn't notice at once
