Simple dc to ac converter?
Discussion in 'The Projects Forum' started by biscuitownz, Jun 10, 2014.
  1. biscuitownz
    Aug 9, 2013
    25
    Hello, I want to make a dc to ac converter for some future projects I have in mind. I've looked around and don't know what kind to use. I plan on using it to convert 12v dc to 12vac etc.
    Thank you
  2. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi bis,
    What frequency for the AC out and current rating.?
    What 'quality' [ Form Factor] do you require for the AC out waveform.?
    E
  3. biscuitownz
    Aug 9, 2013
    25
    Hey, thank you for replying.
    At this point I would prefer around 50-60hz, it can be square/sine wave since I'm really just experimenting with different designs at this point. Also would like at least 5a output although current rating is not a big deal at this point since I just want to learn about the concept first.
  4. ericgibbs
    Jan 29, 2010
    2,575
    389
    Bernard likes this.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    If you are not worried abotu the wave shape, yo can use a 555 timer as "astable oscillator" with approx 50:50 duty cycle, then just put a big cap in series with the output.
    Then you will have a 50 Hz AC squarewave on the other side of the cap.
