Simple DC Motor Question
Discussion in 'The Projects Forum' started by adamfier, Jul 6, 2009.
  1. adamfier
    Jun 12, 2009
    6
    Hey,
    Ok. I made two circuits using 555's. The first outputs for a second and then stops (monostable). the second is a two stage delay... delays for 2 seconds, then outputs for a second.
    What I want to do is connect both of them to a single dc motor in opposite polarity.
    Can I just use diodes to accomplish this? I.e., put a diode on each of the positive wires coming from the circuits into the motor?
  2. DickCappels
    Aug 21, 2008
    2,758
    667
  3. adamfier
    Jun 12, 2009
    6
    Each of the outputs is about 9v. Can you please explain what is going on in that diagram? Im a total novice. Thank you
  4. mik3
    Feb 4, 2008
    4,846
    63
    If you use an H-bridge driver there is no need to use two batteries (one is enough). If you will use two batteries you can reverse the motor by using only two transistors.
    Please post a labeled diagram as to be easy to explain.
