I built the first MOSFET/op amp circuit suggested by SgtWookie in post #23. I replaced the pot with a 3.6K and 6.8K resistors. (I had 6.5 written on my sheet when I went to the store, but the 5 looked like an 8. Just realized that.)Which version did you build?
You shouldn't need a heatsink unless your load turns out to be more than about 550mA.
Testing with a dummy load is a good idea, just in case you made a wiring error.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
