@ crutschow - If you think a 150/200W MOSFET will handle that, then I think we're on the right track. There is a possibility that it will have to be pretty much in limit mode for a second or two during a finale punch of a show though... There may be several output switching actions inside of a 1-3 second window. But I can use a heatsink and afterwards the system would be turned off till the next show...
Should I consider a heat protection circuit as well? How complicated would that be?
Also - I looked up the fairchild fet you used in that diagram and its not available.. at least not through digikey. and with a SMD component, how would i Heatsink it?
