Simple continuity tester
Discussion in 'The Completed Projects Collection' started by Robartes, Feb 19, 2015.
  1. Robartes
    Oct 1, 2014
    57
    13
    This one came about as I was soldering some other circuit together. As I am a bit ham-handed with a soldering iron, I tend to make solder bridges where there shouldn't be any, so while working I am constantly checking continuity (or lack thereof) between neighbouring contacts. I got a bit tired of having to break out a multimeter, plug in the leads, set it to continuity and then fight with the long leads and probes hanging in my way.
    ....................................................[​IMG]
    So I decided to build something quick and dirty. Design parameters (such as there are for such a small project) were:
    - battery powered
    - always on - no on/off switches or anything
    - light weight
    - smallish
    This is what I came up with - a dead simple 555 based oscillator driving a small piezo buzzer:
    The low side switching transistor is biased so that a resistance between the probes of lower than 150 ohm or so turns it on, sounding the buzzer.
    Cobbled together it looks like this:
    Simple, maybe too simple, but it has served me well several times already.
      File size:
      514.9 KB
      490
    Metalmann, absf and planeguy67 like this.
  2. #12
    Nov 30, 2010
    16,665
    7,312
    We need a parts list. I went looking for a buzzer that doesn't need a 555 chip and found nothing around 1 inch in diameter with a reasonable price.
  3. Robartes
    Oct 1, 2014
    57
    13
    Here's the parts list, as far as it goes:
    - the buzzer is a LD-BZEN-1201, it came with one of those ubiquitous Arduino starter kits off Ebay. The buzzer's resonant frequency is 2.4kHz IIRC.
    - the 555 is a TLC555 (standard ones don't run off 3V)
    - the transistor is a 2N2222
    Metalmann and #12 like this.
