Where do you get those 10 Volts from?Your output signal can never go higher than 12 - 10 = 2V
Estimate... base voltage will be roughly 1.2/2.2 * 12 = 6.5VWhere do you get those 10 Volts from?
yea. all the positive peaks faces distortion. what should i do? decrease the Vb by varying R1 and R2? Can input signal's limit be higher?Are you sure the gain is actually decreasing or are you just distorting your waveform?
your input signal is limited to < 44mV... All your plots show significant distortion on the positive peaks (flattened)
All the capacitors care about is the DC signal level. For example, C2 has 6.54V DC on its right and 0V DC on its left.thanks for all the replies.i'm goin onto it. Another question is if i'm using an E-cap for all the 3 capacitors. how should i put the polarity? input signal goes to the negative leg or the positive?
thank you.
so positive leg of C2 should connect to right .Am i right?All the capacitors care about is the DC signal level. For example, C2 has 6.54V DC on its right and 0V DC on its left.
How should it be polarized?
by Duane Benson
by Jake Hertz
by Jake Hertz
by Duane Benson
