Hi everybody,
So I tried to build a simple voltage multiplier and it works perfectly fine, the output is exactly as I predicted.
The problem pops up whenever I try to put a load on it. The output voltage gets down the a third of what it should be. In this case my load is a single electrolytic capacitor - 360V and 2000uF.
The multiplier has 5 stages and the capacitors are 400V and 100uF.
Can somebody please explain to me why does the output voltage drops whenever I connect the big capacitor?
How can I charge this capacitor to about 300V otherwise?
This is my first ever electronics project so my knowledge on the subject is quite low but hopefully you guys can help me.
Thank you very much!
