Simple - Close a Circuit
Discussion in 'The Projects Forum' started by mlouisw, Aug 12, 2014.
  1. mlouisw
    Aug 12, 2014
    newb question, but...
    I need to close a circuit (connect common to open) in order to trigger a gate to open. I'd like to do this using a Spark Core. Do I just use a simple relay to close the circuit....triggering the relay with a pin off the spark?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What is a spark core? Do you mean spark coil? If so, why not control the relay from the low-voltage primary of the coil instead of the HV side?
    You need to explain better what you are trying to do...
  3. kennethorville
    May 16, 2010
  4. GopherT
    Nov 23, 2012
    6,303
    4,021
    Look on the Arduino websites. This is well documented. Search "arduino driving a MOSFET". Yes, you will need a Mosfet transistor as your switch that is turned on/off by your Spark Core/arduino/raspberry pi/micro-of-the-day-on-a-board.
