If the current is going to ground you could use this simple op amp application. Since the - input is a virtual ground it will have no resistance, and have a voltage out for very low current applications. The better the op amp the better it works.
Could you help me out in this setup please? How should I connect it to determine actual current? I am using opamp OPA335
Thanks in advance!
