simple circuit for db vu meter for stereo?
Discussion in 'The Projects Forum' started by electronics_shamim, May 2, 2007.
  1. electronics_shamim
    Apr 28, 2007
    10
    Sirs,
    Does anyone have schematic/component layout/pcb layout for a simple db vu meter for the tape deck, which can be interfaced at the pre-amplifier outputs (stereo) or after tone controls. Can it be built around Transistor BC147/148/548/549 or by IC (LM1458 or LM324).
    Any help on this front is highly solicited.
    regards
    shamim_India.
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    I don't know exacly what you have in mind, but you can try to use a LM3916 VU meter, or the logaritmic version LM3915. Those are analog bar display drivers and you can use any reference voltage with them (up to 36V).
    Refer to:
    http://www.national.com/pf/LM/LM3916.html
    http://www.national.com/pf/LM/LM3915.html
    If you wish, you can use discrete op amps as comparators, but there is no point in doing that.
