Simple Boolean Expression to Circuit
Discussion in 'Homework Help' started by goodbyegti, Apr 28, 2004.
  1. goodbyegti
    Apr 28, 2004
    59
    Hi peoples, just thought i'd comment on how great this site is before i start with my question, have had a good read of the boolean algebra section which has been very useful so far, as does the rest of the site. Anyway heres my question:
    I've designed a circuit and simplified it using a Karnaugh map and come up with the following after simplifying the minterms:
    R = A B C + A B C + A B C + A B C
    which i have simplified to:
    R = CB + CA
    which i hope is correct
    (btw sorry for underlines, they should be over the letters.. but i can't figure out how to do it on here)
    I now need to design a circuit for this expression using only NAND and NOT gates. I've ages messing around with designs and testing them manually against a truth table and I can't come up with anything that works. To put it simply does anyone have an idea of how i could build this circuit using NAND and NOT gates only? Thanks in advance...
  2. haditya
    Jan 19, 2004
    220
    hi
    i cant comment on the your simplification of the expression... i am too sleepy to work it out at the moment..so lets assume it to be correct.
    for your knowledge any gate can be built using a NAND or NOR gate.. these gates are hence called universal building blocks....
    so any logic circuit can be built using them.
    you will need:- 1 NAND gate to make a NOT gate
    2 NAND gates to make a AND gate
    3 NAND gates to make a OR gate.
    4 to make a NOR gate.
    4 to make a EX-OR gate
    5 to make a EX-NOR gate.
    with these clues try and work the problem youself...
    if you still need help msg back.
  3. goodbyegti
    Apr 28, 2004
    59
    thats very useful, thanks a lot, i've got a good idea of what to do now so i'll either figure it out and post up what i think to be the answer or i'll be back asking for more help! thanks again..
  4. goodbyegti
    Apr 28, 2004
    59
    Yep, sorted it, thanks for your help, I built a NOR, OR and AND gate from NAND gates like you said and then just used these to build the expression up..thanks again..
  5. m4yh3m
    Apr 28, 2004
    186
    39
    Y=A'B'C'+AB'C'+AB'C+ABC
    Simplified:
    Y=B'C'+AC
