Simple Bench Power Supply 10A
Discussion in 'The Projects Forum' started by ortiko, Oct 21, 2014.
  1. ortiko
    Oct 21, 2014
    64
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    If you using this circuit, the power transistor are 2N3055, for the power consumption issue, so you better using 4 pcs of 2n3055, at least 3 pcs, and each 2n3055 needs to in series with a 0.2Ω/10W resistor.
  3. ortiko
    Oct 21, 2014
    64
    No images...? Sorry
    Maybe a moderator can erase the above post please
    After a conversation I had with colleague Andreas about it...
    To be continued...
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    Your attachments are wrong.
  5. ortiko
    Oct 21, 2014
    64
    Bath time
    Enough
    Second bath with
    ferric
  6. ortiko
    Oct 21, 2014
    64
    I have replaced the 2n3055 with MJ15003
    It is far better as i know
  7. ortiko
    Oct 21, 2014
    64
    And the resaults are very good !!!
    polishing :)
    Electroprojects
    Drilling it...
    Holes readyto insert parts
  8. ortiko
    Oct 21, 2014
    64
    Mounting the transistors and parts at pcb
    Ready
  9. ortiko
    Oct 21, 2014
    64
    Time to gather all parts and connect them
    Transformer:
  10. ortiko
    Oct 21, 2014
    64
    Something i haven't done yet and must be done is to make the Transformer from 30-0-30 8A to 0-30 8A
    Need to parallel the secondary so i can drain all amperage from 0-30
    Any suggestions will be appreciated.
  11. R!f@@
    Apr 2, 2009
    8,787
    771
    U can if you can isolate the center tap.
    CT secondary are connected as follows.
    30-0-30 --> Start A(30V)-End A joined with start B (0V)-End B (30V).
    A and B are two secondary windings.
    Disconnect End A and Start B ( which is Center tap )
    Connect Start A and Start B together
    Connect End A and End B together.
    After you disconnect center tap you will have isolated secondary A and B windings. You will get 30VAC on each windings.
    After paralleling them if you measure 30VAC on the secondary winding you are good to go.
    Mind you if one winding can handle 8A you can draw max of 16Amps by paralleling them
  12. R!f@@
    Apr 2, 2009
    8,787
    771
    By the way for huge currents, the smoothing cap needs to be 10,000uf or more.
    And the Power should be taken directly from the capacitor terminals.
    Not one from cap and one from bridge as shown in ur picture
    PS. You should add fuses in primary and secondary. You are dealing with high currents
  13. ortiko
    Oct 21, 2014
    64
    Is this what i must do ?
    It is real simple i think but haven't opened a transformer before
  14. tom_s
    Member
    Jun 27, 2014
    287
    342
    my bench supply is similiar to this using lm317/337 mj15003/15004's
    R!f@@ 's comment about fuses should be noted (read as a requirement - common sense)
    edit: no need to 'open' the transformer, from the look of the picture, the two windings have already been soldered together on the 20v secondary side (centre wiring - 2 wires twisted and soldered) just need to break that connection and parallel up as per your diagram.
  15. ortiko
    Oct 21, 2014
    64
    Fuse are in schedule from the beginning of this project :)
    They will be added at the chassis when it will be ready... (pics of it are coming soon)
    I will give it a shot with secondary of transformer this evening
    Thanks for the advice
  16. R!f@@
    Apr 2, 2009
    8,787
    771
    As said, you do not need to dismantle the whole TX.
    The center tap is accessible easily. Just use the iron and untwist the secondary with pliers and you can connect as per ur diagram.
  17. ortiko
    Oct 21, 2014
    64
    This is the old pc case that will be used/modified
    New frontage
    New frontage cuted...
    drilled for the case..
  18. ortiko
    Oct 21, 2014
    64
    I was thinking using the pc case button and make a little very very simple circuit for electronic switch with relay.
    This is what i found with a quick search
    http://www.electronics-tutorials.ws/blog/relay-switch-circuit.html
    This needs extra power supply for vin :(
    If anyone can suggest a very simple one it will be nice to share with me.
  19. R!f@@
    Apr 2, 2009
    8,787
    771
    Power Supplies use toggle switches.
    Safer and better.
    I wonder why you need to use a relay.
    Using that circuit requires the power applied to TX always. If this is not a problem for you, you can use a resistor of appropriate value. Power can be taken from the capacitor.
    Another option is to use a smaller Tx as the standby PSU
  20. R!f@@
    Apr 2, 2009
    8,787
    771
    Mind you a PC uses push button switches which are temporary.
    That circuit requires a toggle switch.
    A PC power button will just on the relay when pressed and switch off the relay when the button is released.
    So I believe you are better off with a power toggle switch
