Simple Battery Monitor
Discussion in 'General Electronics Chat' started by Joster, Jun 26, 2014.
  1. Joster
    Jun 12, 2013
    95
    Hi All!
    I want to know when my battery is at 14V. I can use a comparator using a reference voltage to get a change in state on the output when 14V is reached. I need to convert that change in state to a 1 second pulse to drive a mosfet. What circuit do I use? Maybe there is One that will give me a 1 sec pulse when ever there is a change in state from low to high or high to low??
    Thanks!
    Joster
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
    Use an opamp comparator to detect the voltage, and feed the op amp into a 555 astable to get the pulses.
  3. Joster
    Jun 12, 2013
    95
    ok thanks for responding!
    would the astable 555 not just keep giving pulses? I only want a pulse if the output of the comparator changes state. So I need a pulse which is activated by either a rising edge or a falling edge...
  4. Dodgydave
    Jun 22, 2012
    5,155
    772
    The op amp would give a pulse out on detection, if you want to extend it then use a 555 monostable .
  5. wayneh
    Sep 9, 2010
    12,388
    3,245
    A monostable multivibrator is known as a "one shot".
    The 555 normally triggers on a negative going edge. I'm trying to recall how to get a state-change pulse. Using another 555 is the brute force solution. I think there's a more elegant approach.
  6. Joster
    Jun 12, 2013
    95
    ok...but the battery is going to hit 14V and keep climbing up until I turn the charger off so the output of the op amp will be high once the battery gets to 14V and then remain high...see what I mean?
  7. Dodgydave
    Jun 22, 2012
    5,155
    772
    So whats the mosfet for then?
  8. Joster
    Jun 12, 2013
    95
    I am connecting it to the input of my alarm system. when the input of the alarm system sees a short I get an email that by battery is charged. So really I just need to short the two terminals of the alarm input together... I was thinking of using a relay for that...hense the mosfet or bjt...
  9. Dodgydave
    Jun 22, 2012
    5,155
    772
    ok so use the comparator to turn off the charger using a relay, as well as triggering the alarm then.
  10. Brownout
    Jan 10, 2012
    2,375
    998
    If you use the monostable, it will give you a single pulse out.
  11. Joster
    Jun 12, 2013
    95
    now there is an idea! i think thats the winner!
    I dont think the monostable is edge triggered is it?
  12. Dodgydave
    Jun 22, 2012
    5,155
    772
    yes its negative edge triggered, take pin 2 to 0v to trigger
  13. Brownout
    Jan 10, 2012
    2,375
    998
  14. Joster
    Jun 12, 2013
    95
    I need a solid bat ref but a 10V zener across the battery doesn't work like i thought it would...I need a solid vref for the op amp and want to do it from the bat. the bat will be anywhere from 11v to 14v but i need 10v vef. tried two 5v zeners and current limiting resistor...tried without the resistor still no luck...am i going to have to power it off another supply??? hopefully not
    thanks
  15. inwo
    Nov 7, 2013
    2,435
    315
    What didn't work?
  16. Brownout
    Jan 10, 2012
    2,375
    998
    Never use a zener without a current limiting resistor.
  17. Joster
    Jun 12, 2013
    95
    i thought that i could get a solid 10v reference voltage across the battery with the two 5v zeners and a resistor?
  18. Brownout
    Jan 10, 2012
    2,375
    998
    What did you get? What was the value of the resistor? Why make us guess?
  19. Joster
    Jun 12, 2013
    95
    the resistor is 6.8k
    voltages measured are in pic
  20. Brownout
    Jan 10, 2012
    2,375
    998
    Connect the components in this order: Resistor, Zener, Zener. Like this
    V+
    R
    Z
    Z
    gnd.
    Now take the reference voltage between the resistor and the top zener. You might try a lower value resistor too. Try 300-1k
